Hello, I have redundant 2400 chassis with a single B2250 blade in each. vCMP guests are configured sync failover between chassis, There is no HA at the Viprion Level. I need to setup two blades for a DR Bubble environment needs to be isolated from the existing blade in the default cluster and the vlans cannot mix between the blades. Is it advisable to run a second cluster for the slot 2 and 3 blades to segment the networks? I dont see much documentation on this so any help is appreciated.
I am not sure what you are trying to reach but you can configure different vlan for blades in the 2d slots and assigned them to guests.
blades in provision can run in the cluster only. You can not run blades separately.
