Hello!
I am trying to implement the following scenario:
Users connect to server1.example.com using various URIs. Depending on the URI different authentication methods are supposed to be used, for example:
- https://server1.example.com/uri1/* gets forwarded straight to a pool.
- https://server1.example.com/uri2/* requires Basic authentication.
- https://server1.example.com/uri3/* requires AD authentication.
- https://server1.example.com/uri4/* requires AD authentication with Kerberos Constrained Delegation.
My approach is now to create new virtual servers on a separate VLAN that have different access policies attached. The “main” virtual server has a local traffic policy attached that distributes the traffic according to the URI used. This works fine for scenario #1, but not for #3 or #4 which I have tested.
My understanding is that the traffic flow should look like this:
→ Main_VS → Local Traffic Policy (“if path starts with /uri3 then forward traffic to Sub_VS_AD-Auth”)
→ Sub_VS_AD-Auth → Access Policy → AD-Auth passed → All good.
However, if I have a condition for matching the URI in the Local Traffic Policy forwarding the traffic seems to happen, but the access policy doesn’t get processed, and the client browser gets a reset in the end.
This is what the APM log looks like for a session that does not work:
Nov 11 13:34:36 hostname notice tmm3[16030]: 01490506:5: /Common/APOL_Sub_Server1_Auth-AD:Common:ea55e315: Received User-Agent header: xxxx.
Nov 11 13:34:36 hostname notice tmm3[16030]: 01490500:5: /Common/APOL_Sub_Server1_Auth-AD:Common:ea55e315: New session from client IP x.x.x.x (ST=xx/CC=DE/C=EU) at VIP 172.16.0.5 Listener /Common/Sub_VS_AD-Auth (Reputation=Unknown)
Nov 11 13:34:47 hostname debug apm_websso.7[18421]: 014d0052:7: (null):Common:00000000:Expire thread: TGTMap:0 UCCmap:0
Nov 11 13:34:49 hostname notice tmm[16030]: 01490521:5: /Common/APOL_Sub_Server1_Auth-AD:Common:282b5413: Session statistics - bytes in: 0, bytes out: 0
I would like to note that if I change the local traffic policy rule to forward _all_ traffic to Sub_VS_AD-Auth the issue does not occur.
If I use an iRule like the one below instead the issue does occur.
if { [class match [HTTP::uri] starts_with uri3]} {
log local0. "[IP::client_addr] IP client accepted."
virtual /Common/Sub_VS_AD-Auth
log local0. "Client forwarded."
Would anybody have recommendations what I should change to make it work?
Edit: Main_VS listens on port 443 and has clientssl configured, but no serverssl as Sub_VS listens on a high port and does not use SSL at all. In the access policy under SSO/Auth Domains I have disabled Secure.
