That seems not to be working. While I wait for them to call back I thought I’d poke away at using an iRule.
Now, as they say, I have two problems. A big reason is my iRule knowledge is limited.
1. Is there an optimal way to make this happen using an iRule?
2. Is there a language reference for iRule? I see a lot of cookbook-type references in these forums but without a reference it’s hard to know how much one can actually do with iRules.
Do you want to allow client to make HTTP requests and have the LTM establish HTTPS connections to the pool? Or do you want to redirect client requests made to an HTTP VIP to HTTPS?
There is an iRule wiki which is the primary reference. There are some other links here:
“Do you want to allow client to make HTTP requests and have the LTM establish HTTPS connections to the pool? Or do you want to redirect client requests made to an HTTP VIP to HTTPS?”
In this specific case, the latter. But I would also like to know how to do the former.
To allow clients to make HTTP requests to the VIP and have LTM establish an SSL connection to the pool members, you’d define the VIP on port 80, the pool members on 443 and add a server SSL profile.
I have a problem like this but only some URI are going back to a 443 and the default pool is port 80 so can not use the ssl profile in on the vip level is there anyway to call the server side profile for only some uris
