VIP is not pointing to pool
VIP on port 88 -tcp-automap Servers on port 88
When I am doing telnet on the VIP port 88, I am seeing current connection as 1.
But when I am using that VIP, the request is not going to pool.
Can you the share the VIP configuration here.
-Sekhar
VIP on port 88 -tcp--tcplan-http profile- automap- Servers on port 88 -monitor tcp
Removing the HTTP profile from the config should help resolve the issue. I don’t think http profile is of use here. Let me know if that worked.
-Sekhar
Yep I tested by removing those but it showing me as This site can’t be reached
The connection was reset. Try:
Did you try doing telnet from F5 to that server on port 88.
First of all, testing standard type Virtual Server (VS) with HTTP profile attached using telnet is pointless. This type of VS will always accept telnet connection, even will ACK keystrokes send during telnet session… but nothing will be passed to backend servers.
Second, if you expect any real help please provide some hard data about your config. At least post output of following commands (masking what you consider confidential) - of course you need access to CLI or at least tmsh shell:
  • tmsh list ltm virtual [your VS name]
  • tmsh list ltm pool [pool name used by VS]
There is to many factors that could cause issues to give real advice.
Piotr
Yes I did that from F5 to server and it is connected.
But the VIP is refused.
