VIP Decrypt SSL, but iRule sends to HTTPS
Hello DevCentral,
I’m having a problem with iRule that I’m trying to set.
I have a VIP that receive HTTPS traffic and decrypts it.
The settings for this VIP are:
SSL Profile (Client): {My SSL}
SSL Profile (Server): None
The iRule that I try to set, rewrite the traffic to other HTTPS URL (On a single server).
As you can imagine, it’s not working as the VIP decrypt the SSL on one hand, but the iRule sends the traffic to another HTTPS on the other hand.
This is the iRule syntax:
if { (([string tolower [HTTP::uri]] starts_with “/changepassword”) && ([string tolower [HTTP::host]] equals “qa.domain.com”)) } {
HTTP::header replace Host “qachangepassword.domain.com”
node 192.168.12.233
Without HTTPS (using HTTP) all working well.
If I’m changing the “SSL Profile (server)” on the VIP, all working well too.
Any ideas?
Tnx, Yaniv.
I’m guessing by your description that you have one server that’s listening on 443 (HTTPS) while all of the others are listening on 80 (HTTP). If that’s true, then you should consider applying a server SSL profile to the VIP and enabling/disabling serverside SSL processing with the SSL::disable command based on the request. Here are some examples:
Hi Kevin,
all the servers in the VIP listen on HTTP as the F5 decrypts the traffic for them.
The single server listen on HTTPS.
Could you possibly give me an example for the iRule syntax?
Tnx, Yaniv.
Maybe something like this (with a serverssl profile applied to the VIP):
SSL::disable serverside
if { ( [string tolower [HTTP::uri]] starts_with “/changepassword” ) && ( [string tolower [HTTP::host]] equals “qa.domain.com” ) } {
SSL::enable serverside
node 192.168.12.233 443
Hi Kvein,
Thank you for your help, but i’m unable to change the VIP settings as there is another system which uses it, and working only if serverssl profile set to “None”
Is there maybe an option to apply serverssl profile in the iRule?
Tnx, Yaniv.
You can enable or disable an SSL profile, or change an SSL profile if one is already applied, but you can’t add one on the fly with an iRule. An alternative may be to use a VIP targeting approach. Instead of sending the changepassword traffic to a node, send it to another virtual server (using the virtual command) that you do have control of.
