View Horizon Client with APM as native proxy
Hello,
we would like to use the APM as a native PCOIP proxy with just the View Client (no web plugins/Edge client). Does this mode support SecurID features such as new pin mode? We did some initial tests in the lab but didn’t see the new pin prompt in the View client logon presentation to the user.
thanks
2cushty,
Please open a support case and ask it to be linked to bug id 472744, which tracks implementation of this feature for the native View client. Thanks.
thanks
Works fine for me… APM v1.5.1 and the latest VMWare View Horizon clients. There’s even a how to guide here on devcentral to show you how to set it up.
H
What exactly works for you, Hamish? Do you have user-defined PIN or system-generated PIN? What about you, 2cushty?
We use both user defined and system defined pins. But they’re numeric only. No alphas on them.
I’ll test this again (Probably take me till the weekend to get it set up), because it’s been a while since I had a new pin prompt
We tried user-defined but user wasn’t prompted to enter new pin…
hello Hamish, did you confirm this works for you or not?
