View External Data-Group Records V 11.5
My organization recently upgraded their F5 load balancing appliance to v11.5, and when that happened, the output of list ltm data-group external records became completely useless, in that it simply does not list the records at all. At this point, to get the records, I either have to go into bash and view the files there, or use the GUI. We have a custom interface that used to use REST to get the records that helps consolidate our different technologies we use for load balancing, and also stream line a few processes and provide a much better interface for a few tasks we perform daily. Is there really no other way, now, to view the records? I would prefer it be tmsh/REST only. Any help is greatly appreciated.
Which version and HF are you running, and what’s the syntax of the query you’re using (Can you post as a curl command if possible).
I have a couple of 11.5.1’s around here with latest HF and an 11.6.0 as well I could try on for you.
H
