is a new private key needed for F5 to renew the sha1 to sha2 certificate?
or can the csr be created with existing key
you can use the old csr and key
I think you will need to regenerate the csr with the “-sha256” option with openssl.
With newer versions, such as v11.5.1, sha256 is the default, so you can simply generate a new csr from the Configuration Utility.
