Hi guys,
I’m trying to verify client auth certificate and using this iRule, but from the logs I can see it’s always Accepted even though my trusted_certs only has 1 CN;
i.e: my trusted_certs is “CN” = “3456.mycompany.com” ;
But even if I send 1234.mycompany.com it still says Client Certificate Accepted:CN=1234.mycompany.com
when CLIENTSSL_CLIENTCERT {
if { [SSL::cert count] != 0 }{
set cert [SSL::cert 0]
set subject_dn [findstr [X509::subject [SSL::cert 0]] "CN=" 0 ","]
log "Client Certificate Received: $subject_dn"
if { ([matchclass $subject_dn contains trusted_certs]) } {
log "Client Certificate Accepted: $subject_dn"
log "No Matching Client Certificate Was Found Using: $subject_dn"
reject
Start with using
class match
instead of
matchclass
Also check the datagroup
tmsh list ltm data-group trusted_certs
Hi Blakely,
Yeah I tested that too. Still the same (I better change my code snippet, as I know matchclass uses the $:: object)
and the data group is there..
Can you provide the output of
I can’t seem to include any arguments after data-group
It’s an external file, so you can’t list the contents. Try:
cat /config/filestore/files_d/Common_d/data_group_d/\:Common\:trusted_certs*
Apologies, due to organization rule, I can’t divulge the full CN.
The trusted_certs only contains 1 single line as above. So I created a self-signed cert and key using openssl and send it to the Virtual Server with command:
openssl -s_client -connect host:port -cert 1234.mycompany.com -key 1234.mycompany.com
This is what I see from F5 logs:
I think what is happening is:
The way you created your datagroup has created a datagroup element with a name of “CN” and a value of “3456.xxxx.yyyy.zzz”.
Your extraction from the certificate is CN=1234.xxxx.yyyy.zzz
So the contains match is for “CN”, and will always match. You can create your datagroup without the CN= element at all, or specify the -value specifier to match on the values.
