I am migrating a ha-pair from 6900s to VE(VMware). The first device went off without a hitch. The second…
I promoted the second device to active after migrating to VE and I started looking at “Traffic Summary” to validate that the device was not black holing traffic. While the device was in standby I was getting a throughput average of about 900k. After I promoted it to active it started to go up to 10mb and then everything dropped to 0.
I have never seen these numbers at 0 before so I jumped into the cli and ran “tmsh show net interface” then “reset-stats net interface” and the show again. The stats did not reset…
I ran a tcp capture and I am most certain receiving a ton of traffic. It seems to be a glitch in whatever process is generating the statistics. I tried restarting statsd with no effect. I did an mcpd reload. The Traffic Summary responded for about 60 seconds and then everything dropped to 0 again and I had the same problem resetting stats.
Has anybody else run into this problem? Found a known bug on it?
Thanks! -C
root@(MY-F5)(cfg-sync Changes Pending)(Standby)(/Common)(tmos) show net interface
Net::Interface
Name Status Bits Bits Pkts Pkts Drops Errs Media
In Out In Out
1.1 up 137.6G 8.0G 38.8M 15.6M 0 0 none
1.2 up 8.1G 6.5G 7.2M 11.1M 0 0 none
1.3 up 5.1G 2.8G 5.0M 1.7M 0 0 none
1.4 up 2.0G 1.9G 2.1M 2.8M 0 0 none
mgmt up 356.5M 597.4M 103.6K 140.7K 0 0 100TX-FD
root@(MY-F5)(cfg-sync Changes Pending)(Standby)(/Common)(tmos) reset-stats net interface
Net::Interface
In Out In Out
