From a vCMP host level is the only Self-IPs i need for the mgmt of the device through the management ports? I created a HA vlan on the host, but not self IPs for that vlan on the host level, just the guest level. Is this correct?
Yes, you do not create self-ips on the host for guests, just the vlans. Note the mgt-ips used on the mgt ports aren’t self-ips as such.
cheers
So that being said are the management IPs i give to the vCMP guest essentially accessed through the mgmt ports as well?
yes
