vCMP Guest's running configuration preserved during vCMP Guest state change?
If on the vCMP Host I change vCMP Guest’s state from “deployed” to “configured”, and later back to “deployed”, will Guest resume from running-configuration, or from (cached) initial-configuration.
For example,
  1. on vCMP Guest:
    run /sys failover offline persist
    (notice: without
    save /sys config
  2. on vCMP Host:
    modify /vcmp guest guest-tse state configured
    modify /vcmp guest guest-tse state deployed
Will the vCMP Guest start offline’d or online’d?
