hi,
i am looking for a variable reflecting the big-ip unit-id
in the irule global commands.
this would allow to select a pool with prioritized local
members, when the redundant big-ip´s are located in different
locations.
havent
thanks
stephan
hi,
locations.
havent
thanks
stephan
thanks. but using the physical addresses will not
be possible with mac-masquerading.
the approach with an external class based of an
individual file looks promising.
getting a global variable would make life much
easier. sounds like feature request …
hi,
we got a cr for this:
CR69605 was filed for the RFE to create a variable for the Unit ID.
ciao
stephan
