Variable Passing between Events
Hi !
I am sorry that I am a Newbie for iRule and Tcl command. Could anyone help me the following:
Why can’t it pass the value of $clsub from Event CLIENTSSL_CLIENTCERT to event HTTP_REQUEST. How to solve it and what way can I use for solution?
when CLIENT_ACCEPTED {
set needcert 0;
set gotcert 0;
set crt “”;
set clcert “”;
when CLIENTSSL_CLIENTCERT {
log LOCAL0.warn “cert count=[SSL::cert count] result= SSL::verify_result]”;
if { [SSL::cert count] != 0 or [SSL::verify_result] == 0 } {
log LOCAL0.warn “Good cert! ($needcert)”
set gotcert 1
set crt “[SSL::cert 0]”
set clsub “[X509::subject $crt]”
Subject is obtained successfully shown on log.
log LOCAL0. “$clsub”
if { $needcert == 1 } {
HTTP::release
log LOCAL0.warn “Bad cert!”
reject
log LOCAL0. “HTTP-RQ”
I found $clsub is null on log.
snatpool customer1_snatpool
You can use global variables to span across events. Take a look at this thread (Click here) or do a search on “global variables” to find more examples.
-Joe
My suspicion is that you are actually dealing with a request on a different connection, as many browsers regularly spread requests over multiple connections. I would suggest adding a few log statements both to your HTTP_REQUEST event and to CLIENT_ACCEPTED and log the TCP/IP tuple so you can double check what’s going on.
