Problem this snippet solves:
A Vagrantfile that can be used to boot a BIG-IP box created with a packer template
Code :
# -*- mode: ruby -*-
# vi: set ft=ruby :
VAGRANTFILE_API_VERSION = "2"
Vagrant.configure(VAGRANTFILE_API_VERSION) do |config|
config.vm.define "big-ip01.internal" do | v |
v.vm.box = "/path/to/box/BIGIP-11.6.0.0.0.401.LTM_1SLOT-ide.box"
config.vm.synced_folder ".", "/vagrant", disabled: true
v.vm.network :forwarded_port, guest: 443, host: 10443
v.vm.provider :virtualbox do |p|
p.customize ["modifyvm", :id, "--natdnshostresolver1", "on"]
p.customize ["modifyvm", :id, "--memory", 2048]
p.customize ["modifyvm", :id, "--cpus", 2]
p.customize ["modifyvm", :id, "--name", "big-ip01.internal"]
p.customize ["modifyvm", :id, "--nic1", "nat"]
p.customize ["modifyvm", :id, "--nictype1", "virtio"]
p.customize ["modifyvm", :id, "--nic2", "hostonly"]
p.customize ["modifyvm", :id, "--nictype2", "virtio"]
p.customize ["modifyvm", :id, "--hostonlyadapter2", "vboxnet2"]
end
v.vm.provision "shell", inline: <<-SHELL
while true; do
string=`tmsh show sys failover`
if [[ $string == *"active"* ]]
then
break
else
echo "runlevel is 'unknown' - waiting for 10s"
sleep 10
fi
done
echo "runlevel is now valid, kicking off provisioning..."
SHELL
end
end
