Hi all,
I have a V4 iRule (see excerpt in the bottom) that works properly when I ported it to V9 part of it (the URI::decode) is failing.
Here is an excerpt of the V9 rule:
if { [HTTP::method] == “POST” } {
set HTTP_CONTENT [HTTP::payload 40]
set M_notifyresp_ind [ URI::decode (“%8c%83%98”)]
set MMS_RES [ string range $HTTP_CONTENT 0 2]
if {($MMS_RES == $M_notifyresp_ind )} { <==== Always fails
Debugging this, here is what I found:
M_notifyresp_ind = \x8c\x83\x98 is a string of 3 8-bit hex values.
From tcpdump, I see that the client does send the same hex values but they are 16-bit values and they look like: c28c c283 and c298 this obviously makes my “if {($MMS_RES == $M_notifyresp_ind )}” statement always fail!.
My workaround is to redefine M_notifyresp_ind variable as follows:
set M_notifyresp_ind \x8c\x83\x98 - but I want to know what:
1- Have I missunderstood the use of the URI::decode fonction
2- Has it changed in V9 (compared to its fuctionality in V4)
In comparison here is an excerpt of the rule in V4:
if (http_method == “POST”) {
if (substr(http_content(4), 0, 3) == decode_uri(“%8c%83%98”)) {
And this works properly.
Any comments on this will be appreciated.
Regards.
/Farid
