Have you looked at Local Traffic policy to determine if you can just use that and get rid of this iRule completely? You have the ability in LT policy to pull traffic one way or the other with it and it is a lot more flexible than HTTP Classes were.
Here is an iRule that I had that contains some HTTP Class Events and actions that I moved over to 11.4.1
when CLIENT_ACCEPTED {
set retries 0
when HTTP_CLASS_SELECTED {
if {[HTTP::class] eq "/Common/hqdesktop-securera-8000_class"}{
set backup_pool PHX-hqdesktop-8000.edwardjones.com_pool
if {[HTTP::class] eq "/Common/desktop-securera-8000_class"}{
set backup_pool PHX-desktop-8000.edwardjones.com_pool
when LB_FAILED {
if { $retries < [active_members $backup_pool] } {
LB::mode rr
LB::reselect pool $backup_pool
incr retries
set retries 0
set policy [POLICY::names matched]
if {[POLICY::rules matched $policy] eq "hqdesktop-securera-8000_class_policy_rule"}{
if {[POLICY::rules matched $policy] eq "desktop-securera-8000_class_policy_rule"} {
when LB_FAILED {
incr retries
If you find you need to keep the iRule then hopefully this helps spurs some thoughts on how to re work your iRule
