Anyone have a link to doc showing all the version 10 syntax for iRule conversions. I have several hundred to rewrite and it would be nice if I could eliminate a bunch.
Here are a few I’ve found that might be helpful.
http://devcentral.f5.com/wiki/iRules.BIGIP\_LTM\_v10\_0.ashx
The “new in v10” page is decent.
Which version are you upgrading from? Jason added some documentation to the iRules wiki with changes over the versions:
http://devcentral.f5.com/wiki/iRules.BIGIP\_Commands\_by\_Version.ashx
The CMP page has info on changes you should make for ensuring CMP compatibility:
http://devcentral.f5.com/wiki/iRules.CMPCompatibility.ashx
It’s not complicated once you get things rolling. But it might take some time to figure out the optimizations that you should/must make. If you want, try posting a few anonymized iRules and we can help you convert them.
Aaron
