v 14.1: manual ASM Signature Update not possible?
I’ve got version 14.1.0.5 running and I’m wondering how can I update the ASM Attack Signature according to this:
I’ve to do this manually but the button “Upload File” is greyd out and without Function. Automatic Update is disabled.
Do you have sufficient rights to do this? I’m using 14.1.0.3 and I can use the ‘Upload File’ button. When I log in as another user with the role auditor, the button is greyed out. However I also see the message ‘You do not have the permission to perform this action’ when trying to select the button. Also make sure you are in the /Common partition.
You’re right, but we working with TACACS+ and this function is the first I recognize, that the authorization does not work correctly.
Do you know about any workaround?
ok, it’s known issue: Bug ID 756418
