Hello I have a LTM with several internal node VLANS.
One of the is network 192.168.94.0/24
The external interface has 192.168.91.0/24
The LTM’s default route is 192.168.91.254 (HSRP). When I try to route traffic from the own BIG-IP the traffic is routed without problems.
But, when I try to access the physical address of one node (192.168.94.14) or I try to send traffic messages from the node, I see that traffic gets to the LTM, but it isn’t routed outside it.
I’ve tried with the LTM’s real address and with a floating one as default router for the node.
What do I have to do to make the F5 behave as a router. Do I have to create a 0.0.0.0 vserver on every VLAN?
I’m using version 10.0.0.1
Thank you
________
