I have a user who wants to use different SSL certificates for different domains, but they are all on the same virtual server.
What they want to do for example is:
client requests abc.example.com → use certificate abc
client requests def.example.com → use certificate def
I would think it can be done by using the SSL::renegotiate command, but since the first time the HTTP Request gets to the BIG-IP is after the initial SSL handshake, we would first need to use a wildcard certificate, right?
As for the rule is concerned, I think it would look something like this:
if { [HTTP::host] contains “abc”} {
SSL::profile abc_profile
SSL::renegotiate
} elseif { [HTTP::host] contains “def”} {
SSL::profile def_profile
SSL::renegotiate
Any other suggestions or comments on how to write this rule?
Are there many users that actually use this command for this kind of “two step” negotiation?
