using the client domain in an irule.
Is it possible to use the client domain as a variable in an iRule rather than use a datagroup list of IP addresses/networks. I am wondering about options for doing this. I am assuming this might be done through custom code or using some client header value. But I am not sure of how this might be done.
Could you explain a bit more what you mean? What is the goal?
I think you won’t be able to get this working for Clients at the Internet 1. client don’t need to a have a FQDN set locally which may could be sent as a header 2. reverse DNS for ISP clients may not be maintained
