Using "=" symbol in iRule URL Path
Hey everyone,
I’ve got an iRule where i send traffic to a specific pool based on the URL path they send in. It works well for most URL paths but i’ve received a request to add a new pool from a path that contains a “=” (equals) symbol. The F5 either doesnt recognize the = symbol or it thinks im trying to set a parameter. Either way it doesnt match the URL path so it drops the traffic. When i removed the = symbol then it works perfectly. Any thoughts how to make the F5 understand the = is apart of the URL path and nothing more?
Thanks!
I don’t have access to my lab box to test, but have you tried escaping the ‘=’ with a backslash? \=
Just tried that but unfortunately no adding the backslash didn’t help, it still skipped over it and dropped the traffic.
I tried this irule and it detect equals character:
if {[HTTP::uri] contains "=" } { log local0. "[HTTP::uri] : detected"} else { log local0. "[HTTP::uri] : not detected" }
The log is:
May 25 14:59:49 F5adm info tmm[20143]: Rule /Common/detect-equals : /foo=bar/ : detected
May 25 14:59:53 F5adm info tmm[20143]: Rule /Common/detect-equals : / : not detected
You can use the following irule:
HTTP_REQUEST {
    if {([HTTP::uri] equals "/")  && ([URI::query [HTTP::uri] publication] equals "ecmrc")} {
        pool Oracle_11i_TLS_Mcmaster_Pool_Test
    } else {discard}
or
HTTP_REQUEST {
    switch -glob [HTTP::uri] {
        "/?publication=ecmrc" { pool Oracle_11i_TLS_Mcmaster_Pool_Test }
        default { discard }
HTTP::uri - everything from “/” after the domain name to the end.
HTTP::path - everything from “/” after the domain name to the character before the “?”
HTTP::query - everything after the “?”
Roughly: [HTTP::uri] == [HTTP::path] + ? + [HTTP::query]
Example: http://www.example.com:8080/main/index.jsp?user=test&login=check
URI: /main/index.jsp?user=test&login=check PATH: /main/index.jsp Query: user=test&login=check
