We are running 15.1 and we have a Virtual Server (webservice app) with an irule that only allows certain IP addresses making requests to it.
One of our external service providers have a service in AWS which needs to make requests to this VS, but their IP address is dynamic and thus it changes every 24 hours.
Obviously we have got the FQDN of the external service, but in our irule we need to use RESOLVER::name_lookup to lookup the FQDN based on the [IP::client_addr] and then compare before we can either allow the traffic or drop it.
So far we have managed to return a 94 character string using RESOLVER::name_lookup, but I can not get RESOLVER::summarize to return anything.
Hi there. Sorry for the delay. Since you are using the /Common/f5-aws-dns resolver, did you modify it to include the zone for which your fqdn resides? For example, if I’m going to look up espn.com on my local test box, my aws resolver would need to look like this:
And if I change my iRule to do more logging like this:
when CLIENT_ACCEPTED {
set fqdn espn.com
set lookup_result [RESOLVER::name_lookup "/Common/f5-aws-dns" $fqdn a]
log local0.debug "Lookup: $lookup_result"
set lookup_summary [RESOLVER::summarize $lookup_result]
log local0.debug "Summary: $lookup_summary"
foreach rr $lookup_summary {
log local0.debug $rr
log local0.debug [lindex $rr 4]
Then my results are:
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: Lookup: 000081800001000400000000046573706E03636F6D0000010001C00C000100010000003B00046354A008C00C000100010000003B00046354A00AC00C000100010000003B00046354A037C00C000100010000003B00046354A044
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: Summary: {espn.com. 59 IN A 99.84.160.8} {espn.com. 59 IN A 99.84.160.10} {espn.com. 59 IN A 99.84.160.55} {espn.com. 59 IN A 99.84.160.68}
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: espn.com. 59 IN A 99.84.160.8V
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: 99.84.160.8
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: espn.com. 59 IN A 99.84.160.10
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: 99.84.160.10
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: espn.com. 59 IN A 99.84.160.55
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: 99.84.160.55
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: espn.com. 59 IN A 99.84.160.68
Apr 27 17:38:39 ltm15a debug tmm1[87967]: Rule /Common/resolver_test <CLIENT_ACCEPTED>: 99.84.160.68
I added espn.com to the aws resolver since you’re using it, but in a real scenario, I’d create a standalone resolver specifically for the iRule instead of modifying the aws one.
