Versions of BIG-IP prior to version 9.x used a proprietary (fancy speak for “made up”) syntax for creating iRules. One of the functions that was provided was the “matches_regex” function. While this function has been moved into version 9.x there is a much easier way to do this which leverages the TCL language.
Here is an example which I cooked up for a customer that makes use of the built-in regexp function in the TCL language to check a URL for a regular expression and make a decision based on the result.
rule c180314 {
if { [regexp -nocase {^/nl/app_1} [HTTP::uri]] } {
log local0. "[HTTP::uri] - Matches '/nl/app_1'."
elseif { [regexp -nocase {^/uk/app_2} [HTTP::uri]] } {
log local0. "[HTTP::uri] - Matches '/uk/app_2'."
elseif { [regexp -nocase {^/.*/app_unknown} [HTTP::uri]] } {
log local0. "[HTTP::uri] - Matches '/.*/app_unknown'."
Greg
