Using recursive command outside tmsh, from bash
Hi!
I am trying to get this command running without luck:
tmsh list ltm virtual recursive /* one-line | wc -l
01020036:3: The requested Virtual Server (/bin) was not found.
Please advise
Thank you
J
Try this →
tmsh -q -c "cd /; list ltm virtual recursive"
If you want to use your expression, you should write manually the partition name.
KR, Dario.
