Hello F5, I would like to ask you for your official statement/recommendation of using the configuration design with multiple partitions on BIG-IP systems.
Is it still recommended deployment?
Or is this a recommended deploy only in specific scenarios? If so, could you please state in what use cases you would recommend to opt in for multiple partitions system instead of utilizing vCMP hosts to logically separate the infrastructure?
There has been quite ongoing discussion regarding these and I would like to finally get an end to it :).
Thank you very much for your time and response.
