Using matchclass to check Source IP with HTTP_REQUEST?
F5 Posting
With this iRule I am hoping to direct certain Source IP addresses to Pool-A while directing other HTTP Requests based on URIs to other pools. The syntax is valid, but the iRule doesn’t work for any of the conditions. If I remove the first “matchclass” portion the rest of the iRule works. I suspect that using “matchclass” to inspect a client_addr doesn’t work with the “HTTP_REQUEST” event. But when I tried to nest the HTTP_REQUEST as part of the original CLIENT_ACCEPTED (in order to use matchclass successfully) the syntax was marked invalid. Will I need two seperate IRules to accomplish this ? One with
the “CLIENT_ACCEPTED” event then a second with the “HTTP_REQUEST” event ?
Combined iRule that doesn’t work:
if { [matchclass $::testips contains [IP::client_addr]] } {
pool poolA
if { [HTTP::uri] contains “/cf/” or [HTTP::uri] contains “/hf/”} {
pool poolB
} elseif {
[HTTP::uri] contains “/asweb/”} {
pool poolC
} elseif {
[HTTP::uri] contains “/vh/”} {
pool poolD
pool poolE }
Individual ones that work seperately:
pool poolB
} elseif {
pool poolC
} elseif {
pool poolD
pool poolE }
when CLIENT_ACCEPTED {
pool poolA
pool poolE }
I think this might implement the logic you’re looking for. If not, try adding logging to the iRule and then modify it as you require.
     Check if the client IP is in the testips datagroup
    if { [matchclass [IP::client_addr] equals $::testips] } {
        Select poolA and track that we've selected a pool
       pool poolA
       set pool_selected 1
        Continue checking the URI to select a pool
       set pool_selected 0
     Check if the pool has already been selected
    if {$pool_selected}{
        Exit this event in this rule
       return
        Check the requested path
       switch -glob [HTTP::path] {
          "*/cf/*" -
          "*/hf/*" {
             pool poolB
          "*/asweb/* {
             pool poolC
          "*/vh/* {
             pool poolD
          default {
             pool poolE
Aaron
If you aren’t and don’t plan to add other iRules to this VIP, you could replace the pool_selected variable logic and just disable the HTTP_REQUEST event for clients who are in the datagroup. This would apply to all iRules on the VIP though.
         Select poolA
        pool poolA
         Disable the HTTP_REQUEST event for this TCP connection as it isn't needed
        event HTTP_REQUEST disable
        "*/cf/*" -
        "*/hf/*" {
           pool poolB
        "*/asweb/* {
           pool poolC
        "*/vh/* {
           pool poolD
        default {
           pool poolE
Aaron
