Quick question in regards to using a certificate attribute to authenticate a user. Users have been issued a soft cert with a subject name that represents the users CN. The F5 compares the subject name to the OU to see if there is a user that matches the cert in the user ad object under user mappings. If this matches then the F5 will authenticate the user to the specified website. The problem is the F5 identifies the Subject Name in reverse order than Windows and will not authenticate the user. F5 = CN= OU= OU= OU= OU= DC= Windows alt security identities (user mappings) it reads: DC= OU= OU= OU= OU= CN= Because of this format change F5 will not authenticate the user. Is there a way to have the F5 change the output to the windows format?
You can use FindStr in order to pull out the specific value that you want to compare to whichever AD/LDAP attribute works best for your environment, predominantly userPrincipalName or sAMAccountName.
https://devcentral.f5.com/wiki/iRules.findstr.ashx
For example:
if { [ACCESS::session data get session.ssl.cert.x509extension] contains "CN:" } {
set tmpupn [findstr [ACCESS::session data get session.ssl.cert.x509extension]
"CN:" [Arbitrary number of characters] ""]
ACCESS::session data set session.custom.certcn $tmpcn
log local0. "Extracted OtherName Field: $tmpcn"
You would then use the %{session.custom.certcn} in an LDAP/AD query to validate the user.
The thought from a fellow F5 administrator is that the BIG-IP is still unable to properly present a certificates SN which should have been resolved in BIGIP-9.3.0 per the notes in the article below. I personally cannot replicate this issue and I don’t even know that I fully understand what or how he is attempting this type of authentication though he describes the issue just as it states in the article where the order of the Subject Name is reversed. Note There is a behavior change since BIGIP-9.3.0 for this command to support multiple languages and RFC 2253 compliance. Before the change 1 /CN=Name/OU=UNIT/O=ORG/C=US After the change 1 C=US,O=ORG,OU=UNIT,CN=NAME F5 Cloud Docs
Looking at using the same concept listed above to authenticate the user against user mappings via certificate subject and issuer comparison. i too get the same error listed above when utilizing the same irule.
