Hi all,
I’m going to use AFM rule to block specific ip address on virtual server.
I tried to use ip address that specified in blocking rule but i can still access the virtual server
Can we use blocking rule in ADC mode ?
By default, ADC mode allow any ip addresses
Regards,
Ricky
As you noticed, ADC mode is a default allow configuration, in which all traffic is allowed through the firewall, and any traffic you want to block must be explicitly specified.
So can you check that you not set any rule that blocked you in:
Security > Network Firewall > Active Rules. (if necessary check address list if you use it: Security > Network Firewall > Address Lists).
Keep me update.
Regards
