using a new pool based on cookie
Because of a concurrency bug in our application I’m trying to only allow one appserver to write to our database. I removed 1 of the 4 appservers from our “main” pool and put it into its own pool “login1”. Then I wrote a simple iRule to test if the cookie “username” exists (they’ve logged in) and direct that session to the pool “login1” (the writeable server). I tried it and nothing happended. Then I turned off cookie persistence on “main”, restested, and it still stays in the “main” pool. Any ideas why this would happen?
Here is the test iRule:
if {[HTTP::cookie exists “username”]} {
use pool login1
use pool main
Thanks,
John Boyd
Add some logging to determine where your problems lie:
when HTTP_RESPONSE {
  if { [HTTP::cookie exists "username"] } {
    log "If: username cookie from server, contents are: [HTTP::cookie]"
  if {[HTTP::cookie exists "username"]} {
    log "If: username cookie from client, contents are: [HTTP::cookie]"
    log "If: Current pool is [LB::server pool]"
    use pool login1
    log "If: Pool set to [LB::server pool] by iRule"
    log "Else: Default pool is [LB::selected pool]"
    use pool main
    log "Else: Pool set to [LB::server pool] by iRule"
Oh! sorry, we’re running 9.1.1 (I should have mentioned). So the LB:: commands won’t work..
I replaced my iRule with yours and got these errors:
01070151:3: Rule [login] error:
line 3: [wrong args] [HTTP::cookie]
line 8: [wrong args] [HTTP::cookie]
line 13: [undefined procedure: LB::selected] [LB::selected pool]
john
Try [LB::server pool] instead of selected. Also update my entry with the name of the cookie on lines 3/8. Sorry about that.
So, I logged in just before the break between 13:46 and 13:47 (below). It seems to show the correct pool momentarily but it never goes to that server, then it sets itself back to the default pool “main” even though the cookie “username” still exists.
Here is the tail -f of the log:
Jun 29 13:46:55 tmm tmm[719]: Rule login : If: Current pool is main
Jun 29 13:46:55 tmm tmm[719]: Rule login : If: Pool set to login1 by iRule
Jun 29 13:46:55 tmm tmm[719]: Rule login : If: username cookie from client, contents are: If-Modified-Since: Tue, 20 Jun 2006 20:05:34 GMT
Jun 29 13:47:01 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:01 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:02 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:02 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:06 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:06 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:07 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:07 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:08 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:12 tmm tmm[719]: Rule login : If: username cookie from client, contents are: If-Modified-Since: Thu, 29 Jun 2006 19:30:38 GMT
Jun 29 13:47:12 tmm tmm[719]: Rule login : If: Current pool is main
Jun 29 13:47:12 tmm tmm[719]: Rule login : If: Pool set to login1 by iRule
Jun 29 13:47:14 tmm tmm[719]: Rule login : If: username cookie from server, contents are:
Jun 29 13:47:24 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:24 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:24 tmm tmm[719]: Rule login : If: username cookie from server, contents are:
Jun 29 13:47:33 tmm tmm[719]: Rule login : If: username cookie from client, contents are: Content-Type: application/x-www-form-urlencoded
Jun 29 13:47:33 tmm tmm[719]: Rule login : If: Current pool is main
Jun 29 13:47:33 tmm tmm[719]: Rule login : If: Pool set to login1 by iRule
Jun 29 13:47:33 tmm tmm[719]: Rule login : If: username cookie from server, contents are: qspel12
Jun 29 13:47:33 tmm tmm[719]: Rule login : If: username cookie from client, contents are: qspel12
Jun 29 13:47:34 tmm tmm[719]: Rule login : If: username cookie from server, contents are:
Jun 29 13:47:40 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:40 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:48 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:48 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:52 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:52 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
Jun 29 13:47:52 tmm tmm[719]: Rule login : If: username cookie from server, contents are:
Jun 29 13:47:52 tmm tmm[719]: Rule login : If: username cookie from client, contents are: If-Modified-Since: Thu, 29 Jun 2006 19:30:48 GMT
Jun 29 13:47:52 tmm tmm[719]: Rule login : If: Current pool is main
Jun 29 13:47:52 tmm tmm[719]: Rule login : If: Pool set to login1 by iRule
Jun 29 13:47:53 tmm tmm[719]: Rule login : Else: Default pool is main
Jun 29 13:47:53 tmm tmm[719]: Rule login : Else: Pool set to main by iRule
It actually looks like the basic rule logic is good (simple enough!), but the logging is picking up some random header info instead of the actual cookie values, and the selected pool also won’t be known until the LB_SELECTED event.
So let’s clean up the test as citizen elah suggested, add an LB_SELECTED event, grab the server-set cookie values, and test again:
  if { [HTTP::header exists Set-Cookie] } {
    log "If: server is setting these cookies: [HTTP::header Set-Cookie]"
  log "Current pool is [LB::server pool]"
  if {[HTTP::cookie exists username]} {
    log "If: username cookie from client, contents are: [HTTP::cookie username]"
    use pool login1
    log "Else: No username cookie from client"
    use pool main
when LB_SELECTED {
  log "Selected pool is [LB::server pool]"
Post back with more info if you run into further trouble.
HTH
/deb
