Hey, we have a BIG-IP 12.1.1 Cluster and after 10 seconds I’ve created a user on the active BIG-IP, this system synchronize the User automatically. (autosync is disabled)
What happened there? The Clusterstatus is on “Changes Pending” and the active BIG-IP has a “more recent configuration” warning.
Active BIG-IP
mcpd[6544]: 01070417:5: AUDIT - client tmsh, tmsh-pid-23777, user fib0rkd - transaction 47414394-3 - object 0 - create { userdb_entry { userdb_entry_name "testuser" userdb_entry_shell "bash" } } [Status=Command OK]
mcpd[6544]: 01070417:5: AUDIT - client tmsh, tmsh-pid-23777, user fib0rkd - transaction 47414394-2 - object 0 - create { user_role_partition { user_role_partition_partition "[All]" user_role_partition_user "testuser" user_role_partition_role 0 } } [Status=Command OK]
tmsh[23777]: 01420002:5: AUDIT - pid=23777 user=fib0rkd folder=/Common module=(tmos) status=[Command OK] cmd_data=create auth user testuser partition-access add { all-partitions { role admin } } shell bash
mcpd[6544]: 01070417:5: AUDIT - client Unknown, user admin - transaction 47414401-2 - object 0 - modify { user_role_partition { user_role_partition_user "testuser" user_role_partition_partition "[All]" user_role_partition_role 700 } } [Status=Command OK]
mcpd[6544]: 01070417:5: AUDIT - client Unknown, user admin - transaction 47414411-2 - object 0 - modify { user_role_partition { user_role_partition_user "testuser" user_role_partition_partition "[All]" user_role_partition_role 700 } } [Status=Command OK]
mcpd[6544]: 01070417:5: AUDIT - client Unknown, user admin - transaction 47414438-2 - object 0 - modify { user_role_partition { user_role_partition_user "testuser" user_role_partition_partition "[All]" user_role_partition_role 700 } } [Status=Command OK]
Standby BIG-IP
mcpd[6018]: 01070417:5: AUDIT - client Unknown, user admin - transaction 6361419-2 - object 0 - create { userdb_entry { userdb_entry_name "testuser" userdb_entry_description "testuser" userdb_entry_passwd "***" userdb_entry_is_crypted 1 userdb_entry_gecos "testuser" } } [Status=Command OK]
mcpd[6018]: 01070417:5: AUDIT - client Unknown, user admin - transaction 6361419-3 - object 0 - create { user_role_partition { user_role_partition_user "testuser" user_role_partition_partition "[All]" user_role_partition_role 700 } } [Status=Command OK]
mcpd[6018]: 01070417:5: AUDIT - client Unknown, user admin - transaction 6361461-2 - object 0 - modify { user_role_partition { user_role_partition_user "testuser" user_role_partition_partition "[All]" user_role_partition_role 0 } } [Status=Command OK]
