If I try to use the f5.microsoft_sharepoint_2010 iapp I get an error saying: “01020036:3: The requested persist profile (Sharepoint_Internal_Test_cookie_persistence_profile) was not found” . I think this is the case because we don’t have a LTM license. In the deployment guide “Deploying the BIG-IP System v11 with Microsoft SharePoint 2010 and 2013” the first thing you have to do after you run the iapp is disable the use of the persistent cookie setting. I’ve tried to remove the persistense settings from the iapp template (copy), but that generated other errors. Probably because I don’t know anything about the scripting language. Could anyone modify the iapp for our configuration or hand me a better sollution. We are on BIG-IP 11.2.1 Build 1104.0 Hotfix HF4
Hi MTeeBelgium,
This version of the template allows you to deploy without persistence:
However, since you don’t have an LTM license you may run into further problems. Are you trying to deploy on an Edge Gateway BIG-IP?
thanks
Hi Mikeshimkus, Thx! I could use this iApp without the LTM license (just don’t use persisten cookie). Now all that is left is to see if the apllication works fine with the use of this iApp.
