You can create a wildcard virtual server defined on any destination IP address (0.0.0.0 / mask 0.0.0.0) on port 0. The VIP would typically point to a pool of the two routers for the two links. This is described in the 4.5.x reference guide’s virtual server section:
Wildcard virtual servers
The standard BIG-IP license doesn’t have all of the advantages of the Link Controller license like cost based link selection, but it will get the job done. If you want more info on the differences/advantages of the LC, you can check with an F5 salesperson.
