Dear all
We are currently designing the Authentication & Authorization model of a new web solution and I have the following questions that are key before making the final choice. The reference registry for all the users will be Azure AD Premium. We haven’t completely decided yet if we will go for SAML or OpenID/OAUTH2 regarding the AAA protocol, but it seems SAML is more adapted to our needs. hence the questions below are more SAML related.
The token generation can be handled either by Azure AD or a local AD that is federated with Azure. Microsoft recommends the second option though I don’t know the exact reasons.
Anyway, the questions regarding Big-IP are:
- When we talk about APM replacing ADFS, does it simply sync the tokens that are generated by the main AD or can it act as the token provider itself ?
- What are the pros & cons of having Big-IP handling that completely with the Azure AD compare to connecting the APM to a local ADFS (federated with the Azure AD) ?
