USe F5 to redirect https Traffic
Does anyone know of a clean way for a user that makes an https://mywebsite.com and be passed to two weh servers listens on another secure port.
Do you mean something like the following example?
from https://mywebsite.com to http://mywebsite.com:8443
CB
Sorry for my confusion I mean from https://mywebsite.com to
https://mywebsite.com:8443 or another secure port. I appreciate you
patience and help
If the we servers are listening on a different port going through the vip you could create a vip listening on 443 and then a pool of the 2 webservers on another secure port. The F5 will translate the port without using an iRule. From the client perspective it will look like https://mywebstie.com
i.E. VIP:443 ---> web server1:8443
I hope that helps
CB
Thanks for the help, works but very slow, do you have any other ideas
It shouldn’t be slow if you port translate. Is the LTM experiencing heavy CPU, memory, etc?
CB
Yeah definitley should not be slow.. this is a common function of the LTMs…
Well that all depends on the LTM model and version you are running + the traffic. Do you know what process is taking up memory and CPU?
Bhattman
