facing use curly braces to avoid double substitution error please help me
Could you please elaborate a bit?
Try changing the
and
in your
if ([matchclass...]) {
line to use
and
instead and see if that fixes it.
Mike,
I have modified like this and now i am able to load config without any warning , please confirm about the syntax
You should be able to remove the parenthesis and just keep the curly brackets. But either way I think it looks right.
thanks mike
