You can copy one LTM config to your VE to test. I’d probably try exporting the config to an SCF (using b export config.scf) and then edit that and load it on your VE. You can then merge the config portions you want to test using ‘b merge config.scf’ on VE. Make sure the VE unit is set to standalone unit under System | Platform after importing the config.
