So here is the issue. Traffic that passes through the F5 is encrypted from the client straight to the members. The F5 dosent do the SSL termination, but just a pasthrough. Is it possible to get the Cert, add it into the LTM, and then use it in an iRule to look for a HTTP header?
client--HTTPS--->VS(HTTPS)--->HTTPS---->Member
Basic idea, load up the cert, create an iRULE to use the cert to decrypt the traffic while it passes the LTM.
RGW
You’ll need the SSL/TLS certificate AND private key installed on the BIG-IP. Then create an SSLClient profile and assign it to the relevant Virtual Server. You can then apply iRules and a host of other good LTM features. If you need to re-encrypt to the real servers too, you’ll need to create an SSLServer profile and assign it to the VS too; this will contain the server certificate etc..
I think ProxySSL is the exact feature you are requting, and I blieve it s only in version 11. Search devcentral and askf5 for it.
In a word, no.
When the client sends its certificate to the server, it does so AFTER digitally signing a portion of the response with its private key. In order to pass the client’s certificate in an SSL negotiation to the server, BIG-IP would have to have a copy of the client’s private key.
You have at least two options:
1. ProxySSL - this is a “man-in-the-middle” SSL technique that allows the BIG-IP to be part of the SSL negotiation between endpoints. So you get complete end-to-end SSL but also the ability to (transparently) decrypt and inspect the HTTP data. It’s available starting with v11.
2. Decrypt and pass HTTP headers - if you can justify terminating the SSL at the BIG-IP (with the added performance benefit), this is a tried and true solution. Terminate the SSL and send the X509 certificate data in an HTTP header (or other data component).
