URL to lower string
I need to know, how to make an iRule to translate the complete URL to lower string and then do the redirect.
I have the idea of how to make that happend, but this irule is not working.
when HTTP_REQUEST{
set location [string tolower [HTTP::uri]]
HTTP::redirect "http://[HTTP::host][$location]
That looks okay. You’re missing a closing double quote on the redirect. You could also eliminate the intermediate variable:
   HTTP::redirect "http://[HTTP::host][string tolower [HTTP::uri]]"
Aaron
Also, if you’re doing that for every request and this is on an HTTP virtual server, you’ll get a redirect loop. You could try something like this:
    Check if the URI has any capitalized letters
   if {[string match {*[A-Z]*} [HTTP::uri]]}{
Setting parameter names or values to lower case might actually break the web app parsing of them. Do you want to set the path or the full URI to lower case (/path/to/file.ext versus /path/to/file.ext?param=value)?
Aaron
Great, it works!
It will be a great idea to setup this to work with parameters.
Just to be sure, the way to do it is this?
HTTP::redirect “http://[HTTP::host][string tolower [HTTP::path]]?[HTTP::query]”
Just one update if you only want to check the path:
   if {[string match {*[A-Z]*} [HTTP::path]]}{
      HTTP::redirect "http://[HTTP::host][string tolower [HTTP::path]]?[HTTP::query]"
Aaron
Ok! I forgot to do that change
Thank you!
