I want to have URL redirection from https://xyz to https://xyz:9443 .
version : BIG-IP 10.2.4 Build 732.0 Hotfix HF5
doesn’t HTTP::redirect work?
HTTP::redirect
by the way, you want redirection (not uri rewriting), don’t you?
8 things you can do with a proxy by Lori MacVittie
HTTP::redirect
I want irule for redirection, I used below irule but it doesnt work. when HTTP_REQUEST { HTTP::redirect https://[HTTP::host]:9443[HTTP::uri] } Please suggest if rule is correct or not?
it looks okay to me.
version
root@ve10(Active)(tmos) show sys version | grep -A 6 Package
Main Package
Product BIG-IP
Version 10.2.4
Build 817.0
Edition Hotfix HF7
Date Mon May 20 15:08:56 PDT 2013
config
root@ve10(Active)(tmos) list ltm virtual bar
ltm virtual bar {
destination 172.28.24.9:https
ip-protocol tcp
mask 255.255.255.255
pool foo
profiles {
clientssl {
context clientside
http { }
tcp { }
rules {
qux
snat automap
root@ve10(Active)(tmos) list ltm rule qux
ltm rule qux {
test
[root@ve10:Active] config curl -Ik https://172.28.24.9
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
version
Main Package
Product BIG-IP
Version 10.2.4
Build 817.0
Edition Hotfix HF7
config
ltm virtual bar {
ip-protocol tcp
pool foo
profiles {
clientssl {
context clientside
http { }
tcp { }
rules {
qux
snat automap
ltm rule qux {
test
HTTP/1.0 302 Found
Server: BigIP
Content-Length: 0
I used the below Irule I used below irule but it doesnt work. when HTTP_REQUEST { HTTP::redirect https://[HTTP::host]:9443[HTTP::uri] } But it wont work. can you suggest. I have created two Virtual server. one for VIP port 9443. and another VIP port 443 where we are using redirection by irule.
