I have to Two applications in One server, named as osabc.com and abc.com. What redirection I need is: 1) If request comes from http://abc.com then it should redirect to https://abc.com 2) If request comes from http://osabc.com then it should redirect to http://abc.com (and not on
I tried with IRule
… when HTTP_REQUEST { if { [HTTP::host] equals “osabc.com” } { HTTP::redirect “http://abc.com” } else { HTTP::redirect “https://abc.com” } } …
I’m assuming the “if request comes from” actually means the client is requesting the Host specified? Depending on how your DNS resolves and how you’ve configured your Virtual Server TCP listeners, the iRule below should do the job.
if { [HTTP::host] == "abc.com" }{
HTTP::respond 302 location "https://abc.com"
event disable
TCP::close
} elseif { [HTTP::host] == "osabc.com" }{
HTTP::respond 302 location "http://abc.com"
event disable
TCP::close
Do nothing; the request will be routed to a back-end server as defined in default pool applied to a VS.
Can you please explain me about last statement " do nothing…"
It’s a comment to illustrate what happens if the conditional actions above it are not processed. The whole “else” statement-block is optional and can be removed. Regards,
Hello Hannes, we have configured system default http to https irule on VIP-80 and then redirection from http to https is working perfectly. But we want to redirect some uri like abc.com/product, abc.com/ers that should not redirected towards https that should open via only http://abc.com/product instead of https://abc.com/product can you please help me for the same..
switch -glob [HTTP::host][string tolower[HTTP::path]] {
"abc.com/product*" -
"abc.com/product2*" -
"abc.com/ers*" {
HTTP paths of abc.com as defined above are not redirected to HTTPS
return
"abc.com*" {
All other HTTP paths of abc.com are redirected to HTTPS
event disable
TCP::close
"osabc.com*" {
All HTTP paths of osabc.com are redirected to abc.com
event disable
TCP::close
Notes: you may remove the asterisks at the end of your exclusional HTTP paths (product, productX, ers) for an exact match.
