Godfrey, a redirect will issue a http status 302 and a Get request to the new uri (rather than the original Post). Try HTTP:: respond using a 307 status code. This will maintain the original request type. Plenty of examples on DC. Hope this helps. N
Many browsers will not behave the same way on receiving a 307. Depending on how badly you want this, it is possible to get your irule to parse the POST body, and return a 200 page that contains a new, pre-filled “form” that the user can re-submit to the new location.
Thank you Jie and Nathan. Just an addition. I am looking at performing SSL termination from F5. There are pages that are required to be in HTTPS and others HTTP. Whenever i apply HTTP to HTTPS redirect iRule and to the HTTP VS pool, it works fine, but if i request for a non-HTTPS page, it sticks with SSL (HTTPS)
if this is a new question just make a new question for it, now it becomes quite unclear if you are trying to combine things or not. if you are please post the full new irule.
