URL Re-Writing help needed
Hello All,
I am new to iRule and would like to know how can I solve my below mentioned problem
I have f5 switch and want this switch to filter incoming http requests based on domain / path and etc. After filtering this, it should send ONLY the path of the uri to the pool. Not absolute url
For. e.g.
If incoming request is “http://test.domain.com/path/object.html?args=value”, then f5 switch should send the uri to the pool as “/path/object.html?args=value”
Thanks,
pbelamge
You cannot just send the URI. That would be out of context on an HTTP Request.
You could replace the [HTTP::host] value with another value if you like. You could use a stream profile, string map replace, etc.
Is the client sending an absolute URL in the URI and the web app can’t handle this? If so, do you want to remove the protocol and host from the URI? If that’s the case, you should be able to use something like this:
 Check for an absolute URI
if {not ([HTTP::uri] starts_with "/")}{
if {[scan $abs_uri {%[^/]//%[^/]%s} proto host uri] == 3}{
 Log and set the URI to a local URI
log local0. "\$proto: $proto, \$host: $host, \$uri: $uri"
HTTP::uri $uri
Aaron
