Hello,
Can someone help me with creating an irule?
I want to foward the following.
to
Best Regards
Patrick
Hello,
to
Best Regards
Patrick
do you want redirection or rewriting?
Redirects, Rewrites and App Transfers via iRules by Colin Walker
it has to be an redirect
e.g.
[root@ve10:Active] config b virtual bar list
virtual bar {
snat automap
destination 172.28.19.252:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve10:Active] config b rule myrule list
rule myrule {
if { [HTTP::host] eq "www.example.com" and [HTTP::uri] eq "/test1" } {
HTTP::redirect "http://test1.example.com"
[root@ve10:Active] config curl -i http://www.example.com/test1
HTTP/1.0 302 Found
Server: BigIP
Connection: Keep-Alive
Content-Length: 0
Thank you Nitass! This works for me ![]()
Best Regards
Patrick
