Real Servers IP RND7 ( IP 10.100.100.1) all Https request for app with Domain Name RND14( IP 10.100.100.2) all Https request for app with Domain Name RND8 ( IP 10.100.100.3) all the http request for app with abc.com RND15 ( IP 10.100.100.4) all the http request for app with abc.com
I am having one requirement that Virutal server ( IP 10.100.100.100) should forward all the request to RND7 (10.100.100.1) and RND14 ( 10.100.100.2) for the under mentioned domain names & all other request should be forwarded to RND8 (10.100.100.3) and RND15(10.100.100.4). Kindly share your valuable suggestions-
If terminate the SSL traffic at the F5 you only need one certificate in the virtual server (client). If you also encrypt the traffic to the backend (the two pools) you need to add a certificate to the server setting of the virtual server.
I´m not sure if there is any different between HTTP and HTTPS requests in the iRule coding. If you search a little bit you find some threads in which some other people ask for this one. The answers are everytime that they should use “HTTP_REQUEST”. Have you tried my way?
