I have problem in my F5 irules the scenario is as follows, appreciate your help in this issue
Http://Dev.abc.com/TEST is my primary URL in this /TEST is the contest root redirected by web server now my requirement is when F5 gets request for a URI “/TEST/Maddy” it has to go to a different pool. I have created rule as follows but it is not redirecting for the “/TEST/Maddy”
if { ([HTTP::uri] contains “/TEST/maddy”)}{
pool web_maddy_pool_port_9001
if { [string tolower [HTTP::uri]] equals “/” } {
HTTP::redirect “http://dev.abc.com/TEST”
pool Development_TEST_pool_port_7789
Web_maddy_pool_port_9001 - has IPs of weblogic cluster for Maddy pool
Development_TEST_pool_port_7789 - has IPs of weblogic cluster for default pool
Appreciate your help
The last sentence of your explanation says “it is not redirecting for the “/TEST/Maddy””. Is it possible that the problem is just case sensitivity?
Your iRule code has the following test…
Note the lowercase “m” in the code, but the uppercase “M” in your explanation.
You could do something like what I have below.
When doing it this way the item in the switch statement is absolute, so what I have below “/test/maddy/*” contains the wildcard so that this would equal { [HTTP::uri] starts_with “/test/maddy” }.
This should also make it easier to add to in the future.
switch -glob [string tolower [HTTP::uri]] {
"/" { HTTP::redirect "http://dev.abc.com/test" }
"/test/maddy/*" { pool web_maddy_pool_port_9001 }
default { pool Development_TEST_pool_port_7789 }
Thank you
i think we have kind of identified the issue, but session stickiness is making issues. Anybody has though on overwriting and dropping the cookies?
