URI rewrite using string range??
Hi Friends,
I have a requirement to rewrite a URI which contains dynamic value. Can we do that using string range within an irule? Can you help?
Requirement: I have an https URL (https://xyz.com/Mainboard/OOTW_SYSOPRSA) which has
/Mainboard/
static value and
OOTW_SYSOPRSA
dynamic. Can we get this rewrite using an irule like this (
https://xyz.com/Mainboard/rl?uid=OOTW_SYSOPRSA
I want to add rl?uid= in between the URI.
Is it possible?
you can try :
    if {[URI::path [HTTP::uri]] equals "/Mainboard/"]} {
        HTTP::uri "/Mainboard/rl?uid=[URI::basename [HTTP::uri]]"
Hi Jason, we can also use string range as asked:
HTTP::uri "/Mainboard/rl?uid=[string range [HTTP::uri] 11 end]"
you can also use :
    if {[scan [HTTP::uri] {/Mainboard/%[^/]/%[^/]} dyn_value garbage] == 1 }
        HTTP::uri "/Mainboard/rl?uid=$dyn_value"
