I am trying to do something I think is very simple: when HTTP_REQUEST { HTTP::redirect /broker/api/public[HTTP::uri] }
I want to take an HTTP request coming in and put /broker/api/pubic in front of the URI that is received. I would prefer the client not see the result in their browser.
I have a profile with HTTP profile assigned to it and this IRULE. When I use the rule the code I’m inserting is repeated about 10 times. Help? This is on 11.6.1 on a virtual BIGIP.
The result in my browser when testing is: xyz.abc.com/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/broker/api/public/my/suff
You can do the following :
if { !([HTTP::path] starts_with "/broker/api/public") } {
HTTP::respond 302 Location "/broker/api/public[HTTP::uri]"
Thank you Yann. that is doing what I need. One last question, is there a what to not let the client see the rewritten URI? I’d like them to see what they sent, and have the rewritten go to the server only. Any ideas on this?
Once again thank you.
The problem is that you force a redirect, which causes the user-agent to re-request the page with the new Location value (that is, with /broker/… prepended). Because you perform no check, the client is redirected again, and /broker/… is prepended, again. This happens repeatedly until the UA decides that the Request-URI is too long.
As @Yann says, you could check the Request-URI. However, because you don’t want the new path to be “revealed” to the client, there is a simpler approach. Instead of sending a redirect (which is an HTTP Response message with a 3xx Response Code and a Location header pointing to the new resource path), simply change the Request-URI on the server-side of the proxy. The UA will never “see” the change and there is no direct redirect response sent. This is done thusly:
HTTP::uri "/broker/api/public[HTTP::uri]"
If a UA may directly request something starting with /broker/api/public, then you must place the check as @Yann does.
The irule previously posted do a redirect on the client side. If you require to do URI rewriting, you will need to change the irule :
You may also have a look at the URI rewrite profile that has the advantage to rewrite response headers and payload to remove “/broker/api/public” for the client.
I’m sort of combining the two responses. Its working great so far.
