Hi I am currently in the process of moving sites away from Microsoft ARR to F5
there are quite a few url rewrites involved and the syntax is causing me an issue
current rule on IIS looks like this
rule name=“Rewrite to details”
match url=“^Details/([0-9]+)/([a-z]+)” /
conditions logicalGrouping=“MatchAll” trackAllCaptures=“false” /
action type=“Rewrite” url=“PropertyDetails.aspx?HID={R:1}&L={R:2}” appendQueryString=“false” /
/rule
the question is how do I write this in irule speak? just the match and the rewrite the rest doesn’t matter
any help would be great
nitass
January 29, 2012, 12:17pm
2
i am not familiar with iis rewrite rule. can you give example url?
hi
I don’t have an example to hand but the this works is the property number is given in value 1 and passed to R:1 and the language code in value 2 R:2
so an example would look something like http://host/details/123/en and the output would be http://host/propertydetails.aspx?HID=123&L=en
hope this helps
thanks
nitass
January 30, 2012, 3:11am
4
please feel free to revise.
[root@ve1023:Active] config b virtual bar list
virtual bar {
snat automap
pool foo
destination 172.28.19.79:80
ip protocol 6
rules myrule
profiles {
http {}
tcp {}
[root@ve1023:Active] config b pool foo list
pool foo {
members 200.200.200.101:80 {}
[root@ve1023:Active] config b rule myrule list
rule myrule {
if {[scan [string tolower [HTTP::uri]] {/details/%d/%s} u1 u2] == 2} {
HTTP::uri "/propertydetails.aspx?HID=${u1}&L=${u2}"
[root@ve1023:Active] config ssldump -Aed -nni 0.0 port 80
New TCP connection 1: 172.28.19.253(34582) <-> 172.28.19.79(80)
1327896840.4802 (0.0029) C>S
GET /details/123/en HTTP/1.1
User-Agent: curl/7.15.5 (i686-redhat-linux-gnu) libcurl/7.15.5 OpenSSL/0.9.8r zlib/1.2.3 libidn/0.6.5
Host: 172.28.19.79
Accept: */*
New TCP connection 2: 200.200.200.10(34582) <-> 200.200.200.101(80)
1327896840.4813 (0.0009) C>S
GET /propertydetails.aspx?HID=123&L=en HTTP/1.1
Host: 172.28.19.79
Accept: */*
Hey Nitass
worked a treat, thanks very much
regards
Darren
Hello Nitass,
I have an issue where the following IIS URL Rewrite is causing 502. The application is Cold Fusion (no jokes please) using TomCat and IIS. If I disable the rule F5 works and hits test html pages on each web server. When the IIS URL Rewrite is enabled it fails.
Is there a way to tweak the rule on IIS to make it work, or will the rules need to reside in an iRule?
Any help is much appreciated.
Error:
502 - Web server received an invalid response while acting as a gateway or proxy server.
There is a problem with the page you are looking for, and it cannot be displayed. When the Web server (while acting as a gateway or proxy) contacted the upstream content server, it received an invalid response from the content server.
IIS URL Rewrite Rules/Code:
